Scorpion Telemetrie
Revision as of 13:43, 21 April 2017 by Admin (Talk | contribs) (Created page with "Regulátory Scorpion Tribunus ESC zasílají telemetrii pomocí programovacího portu. Tímto je zprostředkován přenos dat až do jednotky.")
1 ESC configuration
To enable the ESC telemetry, it is necessary to set the Unsolicited telemetry mode in your ESC. With other modes the telemetry will not work. Change Communication protocol to Unsc Telem in the Scorpion Tribunus software. For this purpose Scorpion V link II Cable is needed.
2 Telemetry Cable
3 Interfacing
4.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the Scorpion Tribunus option.
5 Displaying telemetry data
6 Supported models
Battery Voltage
Battery Current
BEC Voltage
Consumed Capacity
ESC Temperature
Scorpion Tribunus 06-120A (SBEC) ✔ ✔ ✔ ✔ ✔
Scorpion Tribunus 06-120A (OPTO) ✔ ✔ ✔ ✔ ✔
Scorpion Tribunus 14-200A (SBEC) ✔ ✔ ✔ ✔ ✔
