Scorpion Telemetrie
Revision as of 13:45, 21 April 2017 by Admin (Talk | contribs) (Created page with "Nastavte '''Communication protocol''' na '''Unsc Telem''' v [http://www.scorpionsystem.com/files/download/Scorpions_Heli_ESC_1.02_log.msi programu Scorpion Tribunus].")
Regulátory Scorpion Tribunus ESC zasílají telemetrii pomocí programovacího portu. Tímto je zprostředkován přenos dat až do jednotky.
1 Nastavení regulátoru
Aby přenos ESC telemetrie fungoval, je nezbytné nastavit telemetrický režim Unsolicited. S ostatními režimy telemetrie fungovat nebude. Nastavte Communication protocol na Unsc Telem v programu Scorpion Tribunus. For this purpose Scorpion V link II Cable is needed.
2 Telemetry Cable
3 Interfacing
4.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the Scorpion Tribunus option.
5 Displaying telemetry data
6 Supported models
Battery Voltage
Battery Current
BEC Voltage
Consumed Capacity
ESC Temperature
Scorpion Tribunus 06-120A (SBEC) ✔ ✔ ✔ ✔ ✔
Scorpion Tribunus 06-120A (OPTO) ✔ ✔ ✔ ✔ ✔
Scorpion Tribunus 14-200A (SBEC) ✔ ✔ ✔ ✔ ✔
