安裝
Revision as of 12:38, 17 May 2017 by Gabrielwong1991 (Talk | contribs) (Created page with "示例2:垂直放 (180° - 左邊)")
正確的安裝將對您的模型操作起了重要的作用。
找一個盡可能減低振動的合適位置, 這個位置通常跟據 製造商說明書裡安裝陀螺儀的位置。
垂直安裝陀螺儀於每個旋轉軸是非常重要的,因為陀螺儀須要正確知道每個軸的位置。 您可以根據自己的偏好和可用空間進行安裝在這八個不同的位置:
  • 橫放 (0°)
  • 橫放 (180°)
  • 橫放 (0° + 倒置放)
  • 橫放 (180° + 倒置放)
  • 垂直放 (0° - 左邊)
  • 垂直放 (180° - 左邊)
  • 垂直放 (0° - 右邊)
  • 垂直放 (180° - 右邊)
如果陀螺儀的插口是面向機頭前方,請選擇'180'。 如果設備倒置安裝的,請選擇“倒置”選項。
安裝示例
在以下照片中,陀螺儀是由雙面膠貼安裝在模型的框架上。
示例1:橫放 (180°)
示例2:垂直放 (180° - 左邊)
In order to better insulate against any vibrations from the model, it is necessary to choose the right double-sided mounting tape. The tape should limit any transmission of vibrations from the model to the Spirit which may produce undesirable flight characteristics. Vibrations may also be caused by incorrectly balanced blades, damaged bearings, bent shafts and other mechanical issues.
