首次飛行
Revision as of 17:09, 17 May 2017 by Gabrielwong1991 (Talk | contribs) (Created page with "起飛前檢查")
如果您確定Spirit配置正確,您可以準備好進行第一次試飛。
我們建議在首次飛行時將陀螺感度(Gyro Gain)設置為50%值。 這將使鎖尾模式(Head-Lock gyro mode)獲得適度的增益(Gain)。
1 起飛前檢查
  1. Turn on the transmitter and connect the battery to the model.
  2. Wait for the initialization, the swashplate jumps.
  3. Tilt the model, ensure the swashplate is compensating in the correct direction on all axes.
  4. Move the tail boom in any direction, the tail slider/rudder blades should compensate in the opposite direction.
  5. Check that input from the transmitter sticks moves the swashplate and tail in the correct directions.
  6. Place the model on a flat surface, use the transmitter sticks to level the swashplate if it isn't already, the tail slider should be approximately in the center of its travel range.
Warning.png If you encounter a problem or something appears wrong at this point, do not try to take off!
2 TAKEOFF
  1. Spool up the main rotor to the desired speed - we recommend to start with a slightly lower RPM.
  2. Slowly increase the collective pitch from zero.
  3. Try to steer the rudder and check whether it has sufficient gain and stop performance is good.
  4. If control is not very precise, slowly add cyclic and rudder gain as needed.
