Translations:Configuration/144/zh-hant
Revision as of 18:22, 18 May 2017 by Gabrielwong1991 (Talk | contribs) (Created page with "接收裡有一幀是不可用的,它將被忽略。 在大多數情況下,它是沒有任何問題的。但如果事件發生頻密,則接收機之間的連接可能出...")
