Translations:Configuration/152/zh-hant
Revision as of 21:01, 18 May 2017 by Gabrielwong1991 (Talk | contribs) (Created page with "電源電壓低於2.9V。 這意味著您必須使用能夠處理更高負載的BEC。 在極少數情況下,電綫連接可能有故障。 (Power supply voltage is lower th...")
