Translations:Configuration/268/zh-hant
Revision as of 00:21, 26 May 2017 by Gabrielwong1991 (Talk | contribs) (Created page with "如果在快速向前飛行期間,模型對輸入的反應太快或者如果模型升降軸俯仰,增加該值直到不再發生。 如果直升機突然上升,這可能...")
