Scorpion Telemetry
Revision as of 19:54, 10 June 2017 by Admin (Talk | contribs) (Marked this version for translation)
Scorpion Tribunus ESC has telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit.
1 ESC configuration
To enable the ESC telemetry, it is necessary to set the Unsolicited telemetry mode in your ESC. With other modes the telemetry will not work. Change Communication protocol to Unsc Telem in the Scorpion Tribunus software. For this purpose Scorpion V link II Cable is needed.
2 Telemetry Cable
3 Interfacing
Servo connector of the Telem UNI cable should be connected to the ESC - programming port.
4.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the Scorpion Tribunus option.
5 Displaying telemetry data
6 Supported models
Battery Voltage
Battery Current
BEC Voltage
Consumed Capacity
ESC Temperature
RPM
Scorpion Tribunus 06-120A (SBEC) ✔ ✔ ✔ ✔ ✔ ✔
Scorpion Tribunus 06-120A (OPTO) ✔ ✔ ✔ ✔ ✔ ✔
Scorpion Tribunus 14-200A (SBEC) ✔ ✔ ✔ ✔ ✔ ✔
