HobbyWing Platinum ESC v3/v4 Drehzahl-Ausgang
Revision as of 12:07, 20 August 2017 by Buell47 (Talk | contribs) (Created page with "Für den Einsatz mit den Spirit ist eine kleine Modifikation des RPM-Kabels erforderlich.")
HobbyWing ESCs v3/v4 sind mit RPM-kabel ausgestattet, der das Signal für den externen Regler liefert. Sie brauchen also nichts anderes zu tun, außer die Kabel richtig anzuschließen und den internen Governor des ESCs auszuschalten.
1 Erforderliche Änderung
- Move the Yellow cable to the middle in the Servo connector.
- You can do so with a needle easily.
- Wire layout
- Yellow wire: RPM Output Signal (PIT pin)
- White wire: Throttle signal (AUX1 port)
- Red wire: BEC Voltage (AUX1 port)
- Black wire: Ground (AUX1 port)
2 Changing ESC mode
It is very important to change ESC mode so that internal Governor is disabled.
This can be made by a Multifunction LCD Program Box. Please see HobbyWing manual.
You can use the following modes:
- Helicopter (Linear Throttle) - great for beginners.
- Fixed-wing - great for advanced (will eliminate problems with slow spoolup and Autorotation Bailout feature).
3 Governor Settings
- Throttle Frequency: 120Hz.
- Throttle Range - Min.: 1100 us.
