ESC telemetry
Revision as of 08:04, 2 October 2017 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
The ESC telemetry is feature that allows you to display data from your Electronic Speed Controller (ESC) directly in the transmitter. Depending on transmitter capabilities you can Log the values and use them for a various purposes.
The ESC telemetry is mediated through the Spirit units (firmware v2.4+) as these are able to read the data and communicate with both receiver and ESC at the same time.
1 List of supported Radios
2 List of supported ESCs
- Castle Creations Phoenix & Talon
- HobbyWing Platinum V4
- Scorpion Tribunus
- Kontronik KOSMIK & JIVE PRO
- Kontronik JIVE
3 Interfacing
4 Telemetry data
- Battery Voltage [V]
- Battery Current [A]
- BEC Voltage [V] - provided by ESC Telemetry or Receiver.
- Consumed Capacity [mAh] - Battery Capacity consumed from the initialization point.
- ESC Temperature [°C] - Usually temperature of the FET transistors.
- Head Speed [RPM] - provided by RPM sensor or ESC. (also with ESC Telemetry disabled)
- Vibration Level [%] - provided by unit itself. (also with ESC Telemetry disabled)
