Intégration HoTT
Revision as of 03:51, 9 November 2017 by GoblinShefford (Talk | contribs) (Created page with "Avec le firmware 2.4 du Spirit firmware 2.4 vous pouvez voir: * '''RPM''' [RPM] - La vitesse de rotation actuelle Governor. * '''Fuel''' [%] - Le ta...")
From version 2.3 the Spirit units support full integration with the Graupner HoTT transmitters. This mean that you can configure the Spirit units completely from your radio without need of a computer.
The integration can work with all HoTT receivers and radios except MZ-4 and MZ-8.
1 Câblage
To allow the integration you have to connect additional cable to your current setup. This cable will connect the Telemetry port of the receiver with the SYS port of the unit. So there should be two connections between unit and receiver for:
  • Channel transmission (PWM, PPM or SUMD)
  • Telemetry and Integration data
Use the Hott Integration cable available in our eshop. Connect it according the following steps:
  1. End with black servo connector should be connected to the receiver on the Telemetry port marked with T label.
  2. End with red servo connector should be connected to the SYS port.
Warning.png It is very important to pay attention during the connection!
If connected wrongly, it will damage the unit permanently. The cable end where red wire is in the middle pin must be always connected to the unit. Never use other cables for this connection!
Info.png Servo connector in the Graupner Hott receivers is connected so that the signal wire is at the bottom.
2 Receiver configuration
In your transmitter, go to the Function (F)/Telemetry/Setting & Data View where you have to change option SENSOR at CHx to YES.
3 Entering the menu
Graupner MZ-18 - Menu intégration
Graupner MZ-18 - General page
4 Sensor Emulation
Available types are:
  • GAM - General Air Module
  • EAM - Electric Air Module
5 Données de télémétrie
Avec cette connexion, le Spirit offrira non seulement l'Intégration, mais aussi les diverses données de télémétrie. Ces données peuvent être affichées sur l'écran principal et peuvent même être enregistrées durant le vol.
  • RPM [RPM] - La vitesse de rotation actuelle Governor.
  • Fuel [%] - Le taux de vibration du modèle (enregistré dans la variable Fuel)
  • BAT1 [V] - Voltage de la batterie principale Voltage
  • Current [A] - Courant dans la batterie principale
  • Capacity [mAh] - Capacité consommée dans la batterie principale
  • BAT2 [V] - Voltage du BEC Voltage (x10) - mettre le Ratio à 25.5
  • T1 [°C] - Température de l'ESC
6 Usage
Info.png Do not forget to click the Save Settings when you want to save the changes permanently.
Info.png Before flying press the ESC button to exit the integration menu.
