Intégration HoTT
Revision as of 05:58, 9 November 2017 by GoblinShefford (Talk | contribs) (Created page with "Configuration du receveur")
From version 2.3 the Spirit units support full integration with the Graupner HoTT transmitters. This mean that you can configure the Spirit units completely from your radio without need of a computer.
The integration can work with all HoTT receivers and radios except MZ-4 and MZ-8.
1 Câblage
To allow the integration you have to connect additional cable to your current setup. This cable will connect the Telemetry port of the receiver with the SYS port of the unit. So there should be two connections between unit and receiver for:
  • Channel transmission (PWM, PPM or SUMD)
  • Telemetry and Integration data
Use the Hott Integration cable available in our eshop. Connect it according the following steps:
  1. End with black servo connector should be connected to the receiver on the Telemetry port marked with T label.
  2. End with red servo connector should be connected to the SYS port.
Warning.png C'est très important de porter attention durant la connexion!
Si l'unité est mal connecté, cela va l'endommager et vous ne serez plus en mesure de l'utiliser. Le câble qui a le fil rouge est au centre doit toujours être connecté a l'unité. Ne jamais utiliser un autre câble pour établir la connexion!
Info.png Servo connector in the Graupner Hott receivers is connected so that the signal wire is at the bottom.
2 Configuration du receveur
In your transmitter, go to the Function (F)/Telemetry/Setting & Data View where you have to change option SENSOR at CHx to YES.
3 Entering the menu
Graupner MZ-18 - Menu intégration
Graupner MZ-18 - General page
4 Sensor Emulation
Available types are:
  • GAM - General Air Module
  • EAM - Electric Air Module
5 Données de télémétrie
Avec cette connexion, le Spirit offrira non seulement l'Intégration, mais aussi les diverses données de télémétrie. Ces données peuvent être affichées sur l'écran principal et peuvent même être enregistrées durant le vol.
Avec le firmware 2.4 du Spirit firmware 2.4 vous pouvez voir:
  • RPM [RPM] - La vitesse de rotation actuelle Governor.
  • Fuel [%] - Le taux de vibration du modèle (enregistré dans la variable Fuel)
  • BAT1 [V] - Voltage de la batterie principale Voltage
  • Current [A] - Courant dans la batterie principale
  • Capacity [mAh] - Capacité consommée dans la batterie principale
  • BAT2 [V] - Voltage du BEC Voltage (x10) - mettre le Ratio à 25.5
  • T1 [°C] - Température de l'ESC
6 Usage
Warning.png Ne jamais changer la configuration durant un vol!
Info.png Ne pas oublier de cliquer sur Save Settings lorsque vous voulez enregistrer les modifications.
Info.png Before flying press the ESC button to exit the integration menu.
