OpenTX 2.2
Revision as of 20:07, 20 November 2017 by GoblinShefford (Talk | contribs) (Created page with "Pour utiliser OpenTX Integration, il est nécessaire d'installer la version 2.2. La version précédente ne prend pas en charge la communication S.Port bidirectionnelle ut...")
OpenTX 2.2 est officiellement disponible maintenant - si vous avez une plus ancienne version, veuillez télécharger la mise à jour et mettre a jour votre récepteur.
Pour utiliser OpenTX Integration, il est nécessaire d'installer la version 2.2. La version précédente ne prend pas en charge la communication S.Port bidirectionnelle utilisée pour l'intégration.
Warning.png Before doing any changes, please Backup all your transmitter profiles and the SD Card content.
Info.png We recommend to check the OpenTX 2.2 page prior the upgrade.
1 SD Card
First you can download the new SD Card content for your transmitter. Extract the archive and move the content to your SD Card.
2 Companion
Please download the latest Companion 2.2 software to your PC:
3 Update
Install the Companion software as you are used to do now.
When you start the program, you will see the Popup window with notification about the new firmware. Click Yes to download and save the firmware to your computer.
4 Flashing
  • By Companion software
  • By built-in bootloader
4.1 With Companion software
4.2 With Built-in bootloader
4.3 Troubleshooting
  • In case that you will see a Blank screen after the upgrade, please try a different Flashing method.
  • If you will see the OpenTX logo but there it will freeze, something is wrong with your SD Card content. Probably there is still a content from older version.
5 Radio Profile
