Stabi mode
Revision as of 10:39, 29 January 2018 by Admin (Talk | contribs)
Info.png It is possible to set a different functions between Banks.
From version 2.3.0 it is possible to activate the Stabi/Function in the two ways:
  • Negative Gyro Gain
  • Separate channel (NEW)
1 Negative Gyro Gain
Info.png Gyro Gain is still used to set the rudder gyro gain. At the same time, positive or negative value will determine if selected function is inactive or active. So it is important to set the gyro gain properly for both normal flight and selected function. Usually same, but opposite values are fine (for example +60%/-60%)
  • Position 0: 50% (normal flight)
  • Position 1: -50% (selected function)
1.2 In the software
1. First step
2.Second step
1.3 Function vs Gyro
Function Gyro gain Gyro mode Mode
Disabled 0 - 100% Head-Lock -
Stabilisation (Scale) 0 - 100% Head-Lock -
Coaxial 0 - 100% Head-Lock -
2 Separate channel
Channel configuration
  1. Open the General/Channels.
Function indicator
  • 0 - function is inactive.
  • 1 - function is active.
Info.png Gyro Gain can still change gyro mode (Head-Lock or Normal).
2.1 Function vs Channel
Function Channel Mode Gyro
Disabled -100% - 0% - Head-Lock / Normal
Rescue (Normal) -100% - 0% - Head-Lock
Rescue (Acro) -100% - 0% - Head-Lock
Stabilisation (Normal) -100% - 0% - Head-Lock
Stabilisation (Acro) -100% - 0% - Head-Lock
Stabilisation (Scale) -100% - 0% - Head-Lock / Normal
Coaxial -100% - 0% - Head-Lock
Disabled 0 - 100% - Head-Lock / Normal
Rescue (Normal) 0 - 100% Rescue Head-Lock
Rescue (Acro) 0 - 100% Rescue Head-Lock
Stabilisation (Normal) 0 - 100% Stabilisation Head-Lock
Stabilisation (Acro) 0 - 100% Stabilisation Head-Lock
Stabilisation (Scale) 0 - 100% Stabilisation Head-Lock / Normal
Coaxial 0 - 100% Stabilisation Head-Lock
Head-Lock and Normal (Rate) mode can be selected by Gyro Gain value. Positive value are activate Head-Lock mode always. Mode - mean that the function is inactive and a normal flight regime is on.
