Scorpion Telemetrie
Revision as of 07:35, 5 April 2018 by Buell47 (Talk | contribs) (Created page with "ESC-Konfiguration")
Scorpion Tribunus ESC hat eine Telemetriefunktion im Programmieranschluss integriert. Dies ermöglicht die Telemetrie-Datenübertragung zum Gerät.
1 ESC-Konfiguration
To enable the ESC telemetry, it is necessary to set the Unsolicited telemetry mode in your ESC. With other modes the telemetry will not work. Change Communication protocol to Unsc Telem in the Scorpion Tribunus software. For this purpose Scorpion V link II Cable is needed.
2 Telemetry Cable
3 Interfacing
Servo connector of the Telem UNI cable should be connected to the ESC - programming port.
4.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the Scorpion Tribunus option.
5 Displaying telemetry data
6 Supported models
Battery Voltage
Battery Current
BEC Voltage
Consumed Capacity
ESC Temperature
RPM
