Scorpion Telemetrie
Scorpion Tribunus ESC hat eine Telemetriefunktion im Programmieranschluss integriert. Dies ermöglicht die Telemetrie-Datenübertragung zum Gerät.
1 ESC-Konfiguration
Um die ESC-Telemetrie zu aktivieren, müssen Sie in Ihrem ESC den Telemetriemodus Unsolicited einstellen. Bei anderen Modi funktioniert die Telemetrie nicht. Change Communication protocol to Unsc Telem in the Scorpion Tribunus software. For this purpose Scorpion V link II Cable is needed.
2 Telemetry Cable
3 Interfacing
Servo connector of the Telem UNI cable should be connected to the ESC - programming port.
4.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the Scorpion Tribunus option.
5 Displaying telemetry data
6 Supported models
Model |
Battery Voltage |
Battery Current |
BEC Voltage |
Consumed Capacity |
ESC Temperature |
RPM |
| Scorpion Tribunus 06-120A (SBEC) | ✔ | ✔ | ✔ | ✔ | ✔ | ✔ |
| Scorpion Tribunus 06-120A (OPTO) | ✔ | ✔ | ✔ | ✔ | ✔ | ✔ |
| Scorpion Tribunus 14-200A (SBEC) | ✔ | ✔ | ✔ | ✔ | ✔ | ✔ |
