Translations:Unequal Collective Pitch/25/en
Revision as of 11:01, 12 April 2018 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
Put push rods/ball linkages perpendicular with respect to the servo arm and swashplate (as close as possible). This mean you have to select which hole of the servo arm is the closest to the perpendicular position. It is always same hole on all cyclic servos. In some models it is unfortunately not possible perfectly which always mean additional error, but you as pilot can't do much about it. Note that also in this step Subtrim (tuning) option should be toggled.
