Translations:Unequal Collective Pitch/30/en
Revision as of 11:12, 12 April 2018 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
At this point, if there is no other imprecision in mechanic your model is configured perfectly. Now you can untick the Subtrim (tuning) option and verify if Positive and Negative angles between main blades are equal. If not, then open the Servos/Servo Travel Correction window and move with a sliders (usually it is enough to move with all 3 values by the same amount). If collective pitch is a higher at one side, move the pitch stick to that side (the lowest or the highest position). Then decrease 3 sliders equally to get equal angle as in the opposite direction. When done correctly, you should get precise angles in both directions. Very advanced pilots can use this correction window even at the step 6 together with Cyclic Leveler but this is usually not necessary.
