Translations:Unequal Collective Pitch/9/en
Revision as of 11:12, 12 April 2018 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
If you are struggling with achieving equal Collective Pitch range for positive and negative side, then the following procedure is for you. If you have hard times to achieve perfect zero degrees between main blades or there is a Geometry 6° imprecision, we recommend to follow the guide.
