Hyperion RPM Sensor
Revision as of 14:59, 12 April 2018 by Admin (Talk | contribs) (Created page with "<languages /> <p></p> <translate> Hyperion RPM Sensor is standard unit for measuring RPM from one phase wire.</translate> File:hyperion-rpm-sensor.jpg == <transla...")
Required modification
For usage with the Spirit units a small modification of the RPM cable is needed.
- Move the White cable to the middle in the Servo connector.
- You can do so with a needle easily.
- Wire layout
- White wire: RPM Output Signal (PIT pin)
- Red wire: BEC Voltage (AUX1/AUX2/CH0 or other power supply port)
- Brown wire: Ground (AUX1/AUX2/CH0 or other power supply port)
