GeoLink Mounting
Revision as of 09:23, 28 May 2018 by Admin (Talk | contribs)
1 Mounting on your helicopter
  • Horizontal (0°) - connector is pointing to main rotor
  • Horizontal (180°) - connector is pointing to tail rotor
  • It is at least 5cm far from a rigid conductive parts such as carbon frame
  • It has clear sky visibility
  • It is perfectly horizontally aligned
Module attachment is normally performed by provided Double Sided tape. Provided tape has extremely good bonding properties so that it can hold more than better even when only two rails of the tape is used.
Some helicopters are equipped with fuselages instead of a boom. In that case there is chance you will have to spend time to achieve flat mounting surface.
Info.png Each circuit containing antennas is very carefully designed to achieve correct impedance. Impedance is changing immediately by placing any parts close to the circuit, especially near antenna. Because PCB is acting as a part of GPS antenna any change to the PCB, including screws has noticeable impact.
2 Wiring
Wiring is done through one JST to JST cable with length of 22cm which is supplied with GeoLink. Longer cable is possible and will be available. For GPS itself a shorter cable is better, because any additional cables attached to the module and even unit could distort the signal.
3 Alignment
halfwidth
