GeoLink Mounting
1 Mounting on your helicopter
- Horizontal (0°) - connector is pointing to main rotor
- Horizontal (180°) - connector is pointing to tail rotor
1.1 Where to mount
- It is at least 5cm far from a rigid conductive parts such as carbon frame
- It is at least 5cm far from any electronics (especially servos)
- It is at least 8cm far from an electric motor
- It has clear sky visibility
- It is perfectly horizontally aligned
1.2 How to mount
Module attachment is normally performed by provided Double Sided tape. Provided tape has extremely good bonding properties so that it can hold more than better even when only two rails of the tape is used.
Never mount GeoLink directly on a thick metallic parts, near a motor or any servo.
Each circuit containing antennas is very carefully designed to achieve correct impedance. Impedance is electrical property which is directly determining performance of antenna. Impedance is changing immediately by placing any parts close to the circuit, especially near antenna. Because PCB is acting as a part of GPS antenna any change to the PCB, including screws has noticeable impact. Thus we highly do not recommend doing any hardware changes to GeoLink module.
1.2.1 Mounting with provided tape
The tape will shortly adhere on the surface tightly and can't be reused anymore.
2 Wiring
3 Alignment
3.1 Alignment procedure
- Power up the Spirit unit.
- Place GeoLink at a flat, aligned horizontal surface anywhere on your model in order to get a precise reference. (for example the Spirit unit)
- Click Set as zero (temporarily) button to reset the angle.
