GeoLink Mounting
Revision as of 17:57, 29 May 2018 by Admin (Talk | contribs)
1 Mounting on your helicopter
  • Horizontal (0°) - connector is pointing to main rotor
  • Horizontal (180°) - connector is pointing to tail rotor
1.1 Where to mount
  • It is at least 5cm far from a rigid conductive parts such as carbon frame
  • It has clear sky visibility
  • It is perfectly horizontally aligned
Choose a position which is not too far, so that provided cable is long enough. Placing module too far on the boom could lead to bad Center of Gravity of the model.
1.2 How to mount
Warning.png Never mount GeoLink directly on a thick metallic parts, near a motor or any servo.
1.4 Unmounting
In some cases pilot might need to remove GeoLink from a model. When provided double sided is used a special care must be taken!
Always try to pull out double sided tape first, not the module. Lastly rotate with the module until the double sided tape will peel off.
Warning.png Never pull the module in any way when mounted with double sided tape! This could bent or crack a plastic part.
2 Wiring
μSpirit SAT - Satellite port
Spirit Primary satellite port
Wiring with Spirit Pro unit.
3 Alignment
3.1 Alignment procedure
  2. Power up the Spirit unit.
  7. Click Set as zero (temporarily) button to reset the angle.
