GeoLink Configuration
Revision as of 22:05, 30 May 2018 by Admin (Talk | contribs) (Compass Calibration)
1 GeoLink Support
GeoLink is supported from firmware version 2.5. In order to utilize all the functions it is necessary to enable the support in the Spirit Settings - General tab.
2 Compass Calibration
All GeoLink modules were fully tested and calibrated. The only thing pilot might need is to re-calibrate Compass. Compass is crucial for determining heading of the model for a proper navigation through space. Compass is sensing Earth's magnetic field (Geomagnetic field) and in this way it can determine heading at any time. Unfortunately Geomagnetic field is different everywhere. Thus if you live outside Czech Republic country where module was calibrated initially, it is recommended to perform new calibration. [TODO: need to perform testing with a pilots]
2.1 How to check
To verify that GeoLink is calibrated correctly for your area, please launch the Spirit Settings and open GeoLink settings window. At Info tab you can see current Heading value.
Please place the model or just GeoLink to the North as close as you can, so that flight direction of the model is front of the arrow. ideally compare to an analogue compass.
When heading to North, you should see approximately 90° +/- 4°. Measured value should not be far from this.
2.2 Odd behavior
If Compass calibration is wrong you will notice that features such as Geo-fence, Return to Home, Position Hold are not working precisely. For example when Return to Home is engaged and model reached its Home position, the model could move in a circle manner around that spot. The bigger is circle, the bigger is Compass heading error. If you can observe this behavior always, then it is clear sign that you need to re-calibrate the Compass.
