Translations:GeoLink Introduction/12/en
Revision as of 11:09, 28 July 2018 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
After this, the module is searching for a satellites. Once module will find enough satellites, it is Fixed and the Status LED become steady on. At this point you are ready to fly. If fixing takes more than 50 seconds then signal quality is bad. This could be caused by a nearby buildings or trees or by wrong module mounting or less likely by RF interference. If you are indoor then fixing time is taking significantly longer or even could never happen depending on how signal is attenuated.
