Translations:GeoLink Configuration/63/en
Revision as of 19:07, 28 July 2018 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
If Altitude Hold is engaged by assigned GeoLink channel there is possibility to use tri-state switch also for programming of a new Home spot. In the Channels window you will be able to see Function as On (1), Off and On (2) which is corresponding to 100%, 0% and -100% channel value.
