Funkce GeoLinku
Revision as of 09:53, 31 July 2018 by Admin (Talk | contribs) (Created page with "Jak to funguje?")
GeoLink nabízí množství funkcí, které mohou být kdykoli aktivovány během létání. Některé mohou být navíc kombinovány mezi sebou pro dosažení požadovaného chování.
1 TTFF akcelerátor
Tato funkce dovoluje výrazné zkrácení doby potřebné pro získání polohy po připojení napájení. Běžně u jiných zařízení je nutné čekat i několik minut. GeoLink dokáže zkrátit tuto dobu na pouhých 6 sekund. Navíc nevyžaduje žádné záložní baterie.
1.1 Jak to funguje?
When module is powered up for the first time at a given day it is trying to find a satellites. It will do so in a normal way (without any time reduction). With GeoLink this should be between 20 - 35 seconds normally (depending on conditions).
Right after the flight and next power up this period is reduced significantly. When powering up within few minutes to hours you can always notice the time required for Fix is shortened.
1.2 How can it help me?
2 Logging
2.1 Logging specification
  • Up to 1.5 hour
  • Up to 63 logged flights
  • Recording period: 1 second
2.2 What is being logged?
  • Position on Earth: Latitude and Longitude
  • Altitude: relative altitude from starting point
  • Speed: flying speed of the model
  • Heading: direction in which model is flying
  • Date and time
2.3 Log viewer
2.4 Log backup and sharing
3 Return To Home
  • in the Spirit Settings by choosing the best spot at the map
  • by transmitter command being at the place considered as a new Home.
3.1 Description
3.2 With Altitude Hold
4 Position Hold
4.1 Description
4.2 With Altitude Hold
5 Geo-fence
5.1 Description
5.2 With Altitude Hold
6 Altitude Hold
6.1 Description
7 Altitude Limit
7.1 Description
If engaged the model will fly without any change in behavior. But as soon as the model will fly under configured altitude the Rescue mode is activated automatically until the model ascend above this level.
