Montáž modulu
Revision as of 08:39, 1 August 2018 by Admin (Talk | contribs) (Created page with "Proto je nezbytné provést následující kroky velmi pečlivě.")
Pro dosažení optimálního fungování je nezbytné správné připevnění k modelu. Pokud se neprovede korektně, bude přesnost funkcí zhoršena nebo v nejhorším případě funkčnost omezena.
1 Mounting on your helicopter
  • Horizontal (0°) - connector is pointing to main rotor
  • Horizontal (180°) - connector is pointing to tail rotor
1.1 Where to mount
  • It is at least 5cm far from a rigid conductive parts such as carbon frame
  • It has clear sky visibility
  • It is perfectly horizontally aligned
Choose a position which is not too far, so that provided cable is long enough. Placing module too far on the boom could lead to bad Center of Gravity of the model.
1.2 How to mount
Warning.png Never mount GeoLink directly on a thick metallic parts, near a motor or any servo.
1.4 Unmounting
2 Wiring
μSpirit SAT - Satellite port
Spirit Primary satellite port
Wiring with Spirit Pro unit.
3 Alignment
3.1 Alignment procedure
  2. Power up the Spirit unit.
  7. Click Set as zero (temporarily) button to reset the angle.
