GeoLink Mounting
Revision as of 13:14, 1 August 2018 by Admin (Talk | contribs)
1 Mounting on your helicopter
  • Horizontal (0°) - connector is pointing to main rotor
  • Horizontal (180°) - connector is pointing to tail rotor
1.1 Where to mount
  • It is at least 5cm far from a rigid conductive parts such as carbon frame
  • It has clear sky visibility
  • It is perfectly horizontally aligned
Choose a position which is not too far, so that provided cable is long enough. Placing module too far on the boom could lead to bad Center of Gravity of the model.
1.2 How to mount
Warning.png Never mount GeoLink directly on a thick metallic parts, near a motor or any servo.
1.4 Unmounting
2 Wiring
μSpirit SAT - Satellite port
Spirit Primary satellite port
Wiring with Spirit Pro unit.
3 Alignment
3.1 Alignment procedure
  2. Power up the Spirit unit.
