GeoLink Configuration
Revision as of 09:42, 2 August 2018 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
1 GeoLink Support
GeoLink is supported from firmware version 2.5. In order to utilize all the functions it is necessary to enable the support in the Spirit Settings - General tab first. After enabling, save the settings and re-power the model.
2 Compass Calibration
All GeoLink modules were fully tested and calibrated. The only thing pilot might need is to re-calibrate Compass. Compass is crucial for determining heading of the model for a proper navigation through space. Compass is sensing Earth's magnetic field (Geomagnetic field) and in this way it can determine heading at any time. Unfortunately Geomagnetic field is different everywhere. Thus if model will be operated outside the Czech Republic it is highly recommended to perform New Calibration. GeoLink modules are factory calibrated for the Czech Republic.
2.1 How to check
To verify that GeoLink is calibrated correctly for your area, please launch the Spirit Settings and open GeoLink settings window. At Info tab you can see current Heading value.
IMPORTANT: Make sure when reading out the Heading, the model is at the horizontal plane. So that at the Module tab you will see 0° inclination. Since some models such as SAB Goblin, MSH Protos are inclined it is necessary to find zero inclination of the model first.
When heading to North, you should see approximately 90 +/- 4°. Measured value should not be far from this.
Info.png We recommend to not use a smart devices for compass heading comparison. These are usually not calibrated at all nor allow the calibration. An analogue compass is the best for comparison.
2.2 Odd behavior
2.3 Calibration process
  1. On the following power up of the model you will immediately notice 3 series of rapid LED flashing on the GeoLink.
  2. The Status LED will be indicating progress of the calibration then. Start moving with the model in all possible directions and angles to mimic a sphere. Any LED flash will indicate that a new calibration data were acquired.
  3. Rotate with the module as long until you will see periodic LED flashing. At this point the calibration is finished. After following re-power the module is ready for operation.
Info.png For 600+ class helicopters we recommend to perform calibration while GeoLink is not mounted. In that way it can be more comfortable and easier.
Info.png Calibration should be done ideally at the flying field but can be performed usually indoor as well.
Warning.png Calibration will not finish until it is fully done. If power is turned off while calibration is not finished, the calibration process will start from the beginning on next power up.
3 How to configure
3.1 Triggering
Warning.png For safety reasons do not engage any GeoLink feature before model is in the air at appropriate altitude.
3.1.1 Stabi function
4 Geo-fence
4.1 Usage
  2. To engage with assigned GeoLink channel - it is required to assign F: GeoLink Geo-fence function in the General/Channels to an available channel.
Info.png Please make sure that Geo-fence Area was defined in the Map tab.
5 Altitude Limit
5.1 Usage
  2. To engage with assigned GeoLink channel - it is required to assign F: GeoLink Altitude Limit function in the General/Channels to an available channel.
6 Return to Home
6.1 Usage
  2. To engage with assigned GeoLink channel - it is required to assign F: GeoLink Return to Home function in the General/Channels to an available channel.
6.2 Modes
6.3 New Home position
7 Position Hold
7.1 Usage
8 Altitude Hold
8.1 Usage
8.2 Modes
9 Correction Gains
9.1 Horiontal Gain
9.2 Vertical Gain
