Řešení problémů
Revision as of 08:10, 2 August 2018 by Admin (Talk | contribs) (Created page with "V případě, že se vyskytne porucha modulu, je pilot informován stavovou LED. Jakýkoli chybový stav je signalizován periodickým blikáním stavové LED. Pokud se objev...")
V případě, že se vyskytne porucha modulu, je pilot informován stavovou LED. Jakýkoli chybový stav je signalizován periodickým blikáním stavové LED. Pokud se objeví chyba např. po havárii modelu, pak je nezbytná jeho oprava.
LED flashing may show up immediately after power up. By number of LED blinks in series you can determine which problem is present.
1 Poruchy
1.1 1x blink
Stored hardware data in GeoLink were lost. Contacting Spirit System support is necessary.
1.2 2x blink
Pressure sensor is not operating correctly. Usually this problem occur when GeoLink is operated for prolonged time under extremely high humidity conditions. Store GeoLink in low humidity environment for few hours until internal condensate will evaporate. If this will not help contact Spirit System support.
1.3 3x blink
Gyro, accelerometer sensors are not operating correctly. Contacting Spirit System support is necessary.
1.4 4x blink
Compass sensor is not operating correctly. Contacting Spirit System support is necessary.
1.5 Constant blinking
This might happen rather in-flight and could signalize unexpected failure. Most probable reason is shock by high electrostatic discharge. Alternatively it could mean error during Flight Log saving if the problem is repeating. Clearing all Flight Logs could help. Contacting Spirit System support is highly recommended.
2 Other notifications
2.1 Calibration process
If you can see 3 series of fast flashing (followed by fast erratic blinks) after power up of the GeoLink then the module is in so called Calibration process. This process can be invoked by pilot through Spirit Settings and must be finished according instructions. Until finished the GeoLink will be inoperable.
