Устранение неполадок Geolink
Revision as of 12:30, 15 October 2018 by Gstatopen (Talk | contribs) (Created page with "Аппаратные данные в GeoLink были потеряны. Необходимо связаться с поддержкой.")
В случае возникновения проблем, GeoLink сигнализирует встроенным светодиодом. Любой сбой индицируется периодически повторяющимися вспышками. Если было падение модели, то неполадка может потребовать ремонта модуля.
Вспышки светодиода могут появиться сразу после включения питания. По количеству вспышек вы можете определить, в чем проблема.
1 Неисправности
1.1 Однократное мигание
1.2 2x blink
Pressure sensor is not operating correctly. Usually this problem occur when GeoLink is operated for prolonged time under extremely high humidity conditions. Store GeoLink in low humidity environment for few hours until internal condensate will evaporate. If this will not help contact Spirit System support.
1.3 3x blink
Gyro, accelerometer sensors are not operating correctly. Contacting Spirit System support is necessary.
1.4 4x blink
Compass sensor is not operating correctly. Contacting Spirit System support is necessary.
1.5 Constant blinking
This might happen rather in-flight and could signalize unexpected failure. Most probable reason is shock by high electrostatic discharge.
2 Other notifications
2.1 Calibration process
If you can see 3 series of fast flashing (followed by fast erratic blinks) after power up of the GeoLink then the module is in so called Calibration process. This process can be invoked by pilot through Spirit Settings and must be finished according instructions. Until finished the GeoLink will be inoperable.
