Телеметрия ESC
Revision as of 06:09, 16 October 2018 by Gstatopen (Talk | contribs) (Created page with "Телеметрия ESC")
The ESC telemetry is feature that allows you to display data from your Electronic Speed Controller (ESC) directly in the transmitter. Depending on transmitter capabilities you can Log the values and use them for a various purposes.
The ESC telemetry is mediated through the Spirit units (firmware v2.4+) as these are able to read the data and communicate with both receiver and ESC at the same time.
1 List of supported Radios
Info.png These radios support full integration/telemetry as well.
2 List of supported ESCs
3 Interfacing
4 Telemetry data
  • Battery Voltage [V]
  • Battery Current [A]
  • Head Speed [RPM] - provided by RPM sensor or ESC. (also with ESC Telemetry disabled)
