Вывод оборотов с HobbyWing Platinum ESC v3/v4
Revision as of 07:01, 16 October 2018 by Gstatopen (Talk | contribs) (Created page with "Вывод оборотов с HobbyWing Platinum ESC v3/v4")
HobbyWing ESCs v3/v4 are equipped with RPM lead that is providing signal for the external governor. So you do not need to do anything else except connect the cables properly and turn off the internal Governor of the ESC.
1 Required modification
For usage with the Spirit units a small modification of the RPM cable is needed.
- Move the Yellow cable to the middle in the Servo connector.
- You can do so with a needle easily.
- Wire layout
- Yellow wire: RPM Output Signal (PIT pin)
- White wire: Throttle signal (AUX1 port)
- Red wire: BEC Voltage (AUX1 port)
- Black wire: Ground (AUX1 port)
2 Changing ESC mode
It is very important to change ESC mode so that internal Governor is disabled.
This can be made by a Multifunction LCD Program Box. Please see HobbyWing manual.
You can use the following modes:
- Helicopter (Linear Throttle) - great for beginners.
- Fixed-wing - great for advanced (will eliminate problems with slow spoolup and Autorotation Bailout feature).
3 Governor Settings
- Throttle Frequency: 120Hz.
- Throttle Range - Min.: 1100 us.
