Вывод оборотов с HobbyWing Platinum ESC v3/v4
Revision as of 07:03, 16 October 2018 by Gstatopen (Talk | contribs) (Created page with "Для использования со Spirit требуется небольшая модификация разъема RPM.")
HobbyWing ESCs v3 / v4 оснащены проводом RPM, который выдает сигнал для внешнего гувернера. Поэтому вам не нужно ничего делать, кроме как правильно подключить провод и отключить внутренний гувернер ESC.
1 Необходимая переделка
  • Move the Yellow cable to the middle in the Servo connector.
  • You can do so with a needle easily.
Wire layout
Yellow wire: RPM Output Signal (PIT pin)
White wire: Throttle signal (AUX1 port)
Red wire: BEC Voltage (AUX1 port)
Black wire: Ground (AUX1 port)
2 Changing ESC mode
It is very important to change ESC mode so that internal Governor is disabled.
This can be made by a Multifunction LCD Program Box. Please see HobbyWing manual.
You can use the following modes:
  • Helicopter (Linear Throttle) - great for beginners.
  • Fixed-wing - great for advanced (will eliminate problems with slow spoolup and Autorotation Bailout feature).
3 Governor Settings
  • Throttle Frequency: 120Hz.
  • Throttle Range - Min.: 1100 us.
