Instalación
Revision as of 13:24, 16 September 2016 by Admin (Talk | contribs) (Created page with "Encontrar un lugar adecuado donde las vibraciones son lo más bajo posible - esto es por lo general el mismo lugar que se indica por el fabricante para el montaje de un girosc...")
Correctamente montaje del Espíritu juega un papel importante para el correcto funcionamiento de su modelo.
Encontrar un lugar adecuado donde las vibraciones son lo más bajo posible - esto es por lo general el mismo lugar que se indica por el fabricante para el montaje de un giroscopio.
It is VERY important that the unit will be mounted so that the unit is exactly perpendicular to each rotational axis. Depending on your preference and available space it can be mounted in eight different positions:
  • Horizontal (0°)
  • Horizontal (180°)
  • Horizontal (0° + inverted)
  • Horizontal (180° + inverted)
  • Vertical (0° - left side)
  • Vertical (180° - left side)
  • Vertical (0° - right side)
  • Vertical (180° - right side)
Mounting examples
Example 1: Position is Horizontal (180°)
Example 2: Position is Vertical (180° - left side)
In order to better insulate against any vibrations from the model, it is necessary to choose the right double-sided mounting tape. The tape should limit any transmission of vibrations from the model to the Spirit which may produce undesirable flight characteristics. Vibrations may also be caused by incorrectly balanced blades, damaged bearings, bent shafts and other mechanical issues.
