Нормальный режим
Revision as of 12:57, 16 October 2018 by Gstatopen (Talk | contribs) (Created page with "Дрейф хвоста")
Нормальный режим - это такой режим гироскопа, при котором он компенсирует увод хвоста. Такой режим еще называют Rate. В отличие от режима удержания хвоста (Heading Hold) , Нормальный режим не выдерживает заданное направление строго и хвост может немного уплывать.
1 Дрейф хвоста
When hovering, drifting should not occur if the rudder mechanics has correctly configured neutral position. But in case of a wind, the drift can occur. This mode is suitable only for forward flight.
2 Activation
To activate this mode set the Gyro Gain to a negative value. To be sure that the mode is active, open the Diagnostic tab. Gyro Bar should display Normal when Normal mode is active. This mode can work only when Stabi/Function parameter is set to Disabled.
3 Usage
If you want to set the rudder mechanic precisely, we recommend to use this mode. Simply activate the mode during hovering and observe if there is any drift. If there is a drift, then it mean that the rudder neutral position is not configured well. Try to change push rod length of the rudder control mechanics to compensate this drift. This configuration can greatly improve performance of the rudder including stopping behavior.
