Стабилизация (в нормале)
Revision as of 07:29, 17 October 2018 by Gstatopen (Talk | contribs) (Created page with "Характеристики")
Режим стабилизации - это функционал, который помогает пилоту сохранять положение модели в воздухе. Модель может полностью управляться пилотом, но в отличие от обычного режима полета, модель будет автоматически выравниваться в горизонт.
Режим активируется с передатчика специально назначенным тумблером. Стабилизация работает пока тумблер в активном положении. В противном случае, полет идет в обычном режиме.
1 Характеристики
  • Upon activation of the Stabilisation (Normal), the model will attain horizontal level rather slowly (Always skids down).
  • Cyclic stick input from the pilot will tilt the model to a degree which can be configured by Direction control rate parameter.
  • It is perfect for learning basic transitions and stationary hovering.
  • In this mode it is impossible to perform a flips or rolls. This mean that this mode is not suitable for learning acrobatics.
  • Collective pitch and rudder is controlled by the pilot as in a normal flight mode.
Info.png This mode will not maintain altitude or a spot on position. It can make hovering noticeable easier.
2 Setttings
To make it comfortable for your needs you can set the Direction control rate parameter. This will affect how the helicopter will respond to the sticks.
  • Low values are recommended for beginners - it will return faster to the horizontal position and not allow tilting to a high angle.
  • Higher values will allow to tilt the model to a higher angle and to achieve faster flight speed.
