OpenTX 2.2
Revision as of 15:30, 17 October 2018 by Gstatopen (Talk | contribs) (Created page with "SD карта")
Официально выпущен OpenTX версии 2.2, если вы используете более старую, пожалуйста скачайте и обновите.
Для работы интеграции необходимо установить версию 2.2.
Warning.png Перед началом любых манипуляций, сделайте резервную копию всех моделей в передатчике и содержимого SD карты.
Info.png Мы рекомендуем периодически проверять страницу OpenTX на предмет обновлений.
1 SD карта
First you can download the new SD Card content for your transmitter. Extract the archive and move the content to your SD Card.
2 Companion
Please download the latest Companion 2.2 software to your PC:
3 Update
Install the Companion software as you are used to do now.
When you start the program, you will see the Popup window with notification about the new firmware. Click Yes to download and save the firmware to your computer.
4 Flashing
  • By Companion software
  • By built-in bootloader
4.1 With Companion software
4.2 With Built-in bootloader
4.3 Troubleshooting
  • In case that you will see a Blank screen after the upgrade, please try a different Flashing method.
  • If you will see the OpenTX logo but there it will freeze, something is wrong with your SD Card content. Probably there is still a content from older version.
5 Radio Profile
