Graupner SUMD/ru
Revision as of 09:15, 19 October 2018 by Gstatopen (Talk | contribs) (Created page with "Если вы еще не подключали питание, подключите BEC или 1-2S Lipo.")
С передатчиком Graupner HoTT вы можете использовать однопроводное цифровое подключение SUMD. Для соединения можно использовать обычный сервокабель.
1 Подключение
Подсоедините кабель как на фото. В Spirit в порт RUD, в приемнике в последний канал. Для GR-12/GR-12L он подписан 6
Info.png Имейте ввиду, что сигнальный провод оранжевого цвета ближе к верхней части приемника.
Warning.png Never connect a power supply to the SYS or ELE/PIT/AIL ports!
2 Spirit Settings
After initialization of the unit you can start the software. To allow the connection set the Receiver type to SRXL/SUMD in the General tab.
Now save the settings (CTRL+S) or in the Backup tab/Unit - Save.
3 Receiver configuration
By default SUMD transmission is disabled in the HoTT receivers. It is necessary to enable it in the (F) Function/Telemetry/Setting & Data View menu (HoTT MZ series).
Change SUMD at CH6 to YES.
4 Usage
Now you can restart the unit. After the initialization the SUMD connection will work. Reverse of some channels might be necessary depending on the radio model - please check the Diagnostic tab.
The transmission is able to carry all the channels. Usually SUMDOF12 option (if available) is fine.
Info.png For MX-12/MZ-12 transmitters it is needed to change the channel mapping in the Spirit Settings. Please go to the General tab/Channels and change Gyro Gain to Channel 7.
