SPM4649T
Revision as of 20:58, 30 January 2020 by Admin (Talk | contribs)
SPM4649T is telemetry enabled receiver that is able to transfer all channel data and telemetry at the same time. This mean that you will not need to connect anything else except one cable.
Info.png In case that your SPM4649T receiver is not bound yet, you can do so by a Bind plug. Connect the Bind plug to the servo socket. Then power up the receiver (you can use BEC power supply and/or free port in the unit such as CH0 or AUX2). Optional satellites can be bound normally as described in the Manual.
1 Spektrum satellites (optional)
  • Spirit 2 - 1x SPM4649T + 0-2x Spektrum satellites
Info.png In case that the ESC telemetry is used, the primary satellite can't be connected. For the Castle Creations and Kontronik Kosmik/Jive Pro ESC telemetry primary satellite can be still used.
2 Spirit Settings
3 Radio Integration
If you want to use Integration and Telemetry features please continue with Spektrum Integration page.
