SPM4649T
SPM4649T это приемник с поддержкой телеметрии, который позволяет передавать одновременно значения каналов и данные телеметрии. Это значит, что вам не потребуется подключат дополнительные кабели.
In case that your SPM4649T receiver is not bound yet, you can do so by a Bind plug. Connect the Bind plug to the servo socket. Then power up the receiver (you can use BEC power supply and/or free port in the unit such as CH0 or AUX2). Optional satellites can be bound normally as described in the Manual.
SPM4649T receiver Jeti integraction cable must be connected to the Servo socket. This socket is used also for Binding. Spirit unit Other end of the Jeti integration cable should be connected so that Orange wire is in the AIL pin. Powering plug with Red and Brown wires in the RUD port. (see the photo)
1 Spektrum satellites (optional)
- Spirit 2 - 1x SPM4649T + 0-2x Spektrum satellites
- Spirit Pro - 1x SPM4649T + 0-2x Spektrum satellites
- Spirit - 1x SPM4649T + 0-1x Spektrum satellites
- µSpirit - 1x SPM4649T + 0-1x Spektrum satellites
In case that the ESC telemetry is used, the primary satellite can't be connected. For the Castle Creations and Kontronik Kosmik/Jive Pro ESC telemetry primary satellite can be still used.
2 Spirit Settings
3 Radio Integration
If you want to use Integration and Telemetry features please continue with Spektrum Integration page.
