SpiritRS Binding
Revision as of 13:42, 2 June 2020 by Admin (Talk | contribs) (Not recognized by radio)
In order to Bind Spirit RS with your radio use supplied Bind plug.
1 Binding Procedure
  1. Insert Bind plug in the SYS port and connect Power supply to the Spirit unit. (For example ESC/BEC at the THR port)
  2. Spirit unit will start to blink with the Status LED periodically.
  3. Then power up your radio.
  4. Radio will ask if you wish to Bind to the receiver. Confirm by pressing Yes button.
1.1 Not recognized by radio
In case you already bound a receiver or Spirit RS with selected Model profile, you might need to start Binding process again.
Go to Model/Heli Tuning and press middle button under display. Then select ̈́Pair primary module.
Subsequently you can Turn Off and Turn On your radio. During powering new receiver should be recognized.
