SpiritRS Preparation
To operate Spirit RS unit any JETI DUPLEX radio can be used.
Supported radios are:
- DC-14
- DC-16
- DC-16 II
- DC-24
- DS-12
- DS-14
- DS-16
- DS-24
We recommend to start with clear model profile as you will need only few changes.
Spirit System offer DS-12 radio tailored specially for the Spirit RS. This mean you will be able to utilize completely all features out of the box.
1 Beginning
2 Turning On and Off
3 New Profile
In the Basic Properties menu select Heli to Spirit and continue to another page. (Please note transmitter update 5.03 is required for this option).
4 Basic Helicopter settings
4.1 Flight Modes
Non-Spirit Jeti radio might need to get extension module for Flight modes. Alternatively you can use only 3 Flight modes.
Instead of Autorot. flight mode you can set Throttle Cut switch.
4.2 Throttle Curve
4.3 Pitch Curve
4.4 Gyro Gain
For the beginning you can use these values. Positive value will activate Head-Lock Gyro mode, while -50% will engage Normal (Rate) mode.
For further Gyro Gain tuning you can set 50, 60, 70% gains or assign a rotary knob.
