Translations:SpiritRS Mounting/9/en
Revision as of 12:37, 3 June 2020 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
In order to better insulate against any vibrations from the model, it is necessary to choose the right double-sided mounting tape. The tape should limit any transmission of vibrations from the model to the Spirit which may produce undesirable flight characteristics. Vibrations may also be caused by incorrectly balanced blades, damaged bearings, bent shafts and other mechanical issues.
