Installation
Revision as of 13:52, 15 September 2016 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
Properly mounting of Spirit plays an important role for the correct operation of your model.
Find a suitable location where vibrations are as low as possible - this is usually the same location shown by the manufacturer for mounting a gyro.
It is VERY important that the unit will be mounted so that the unit is exactly perpendicular to each rotational axis. Depending on your preference and available space it can be mounted in eight different positions:
  • Horizontal (0°)
  • Horizontal (180°)
  • Horizontal (0° + inverted)
  • Horizontal (180° + inverted)
  • Vertical (0° - left side)
  • Vertical (180° - left side)
  • Vertical (0° - right side)
  • Vertical (180° - right side)
Mounting examples
Example 1: Position is Horizontal (180°)
Example 2: Position is Vertical (180° - left side)
In order to better insulate against any vibrations from the model, it is necessary to choose the right double-sided mounting tape. The tape should limit any transmission of vibrations from the model to the Spirit which may produce undesirable flight characteristics. Vibrations may also be caused by incorrectly balanced blades, damaged bearings, bent shafts and other mechanical issues.
