SpiritRS Setup
All Spirit units can be configured through radio in the full extent without usage of computer. You can perform full setup of the Spirit RS and tune all flight parameters easily in Device Explorer menu.
1 Spirit Integration
Sprit Integration is interface for configuration of the Spirit unit. All changes related to the Spirit RS can be done from there. You can enter and close it anytime you wish.
It is highly advised to not enter the setup while flying! If you were performing changes in this menu, always close it according section Closing Spirit menu.
To open Spirit setup you can proceed in the following way.
Open Spirit menu in the Model/Heli Tuning.
In case you are getting error message when opening the integration menu, please install the latest JETI integration file - available at our web pages.
SPIRIT-3.X.zip archive must be extracted and all the files copied to the Devices directory inside your Radio.
1.2 Spirit Settings
Spirit menu is almost identical to computer software called Spirit Settings that can be also optionally used.
You can easily change any parameter and changes are applied immediately. But to store any changes do not forget to Save the settings.
Click at the Save Settings in the Spirit menu to save all changes you have made in the Spirit RS settings. Otherwise after re-power changes are returned to the previous values.
To continue with flying please close the Spirit menu by selecting Close the integration menu. Once this is performed, Status LED of the unit must remain steady On.
2 Configuring Receiver part
To configure E1 telemetry port you can open Device Explorer and perform settings there.
Open Menu and press right button under display. This will open Device Explorer instantly. Alternatively you can go trough Model/Device Explorer menu.
Then select REX-RS device. All changes in the settings are saved immediately.
3 Spirit RS setup
To prepare Spirit unit for flight it is necessary to go through Setup Wizard first. This process is required only once, always for a new model.
You can find the Setup Wizard in the Spirit Integration menu.
4 Throttle output
By default THR port is unassigned. Please assign Throttle to Channel 1.
Open the Spirit Integration menu and go to the General/Channel Mapping. There please select ch. 1 for Throttle function.
Then confirm with Verify mapping. From that moment THR port is active and you will be able to for example calibrate your ESC.
