Telepítés
Revision as of 10:17, 17 August 2020 by PSzakra (Talk | contribs) (Created page with "Találjon meg egy megfelelő helyet, ahol a vibráció a lehető legalacsonyabb legyen, ez általában az, amelyet a gyártó jelez a giroszkóp beszereléséhez.")
A Spirit megfelelő felszerelése fontos szerepet játszik a modell megfelelő működésében.
It is VERY important that the unit will be mounted so that the unit is exactly perpendicular to each rotational axis. Depending on your preference and available space it can be mounted in eight different positions:
  • Horizontal (0°)
  • Horizontal (180°)
  • Horizontal (0° + inverted)
  • Horizontal (180° + inverted)
  • Vertical (0° - left side)
  • Vertical (180° - left side)
  • Vertical (0° - right side)
  • Vertical (180° - right side)
Mounting examples
Example 1: Position is Horizontal (180°)
Example 2: Position is Vertical (180° - left side)
In order to better insulate against any vibrations from the model, it is necessary to choose the right double-sided mounting tape. The tape should limit any transmission of vibrations from the model to the Spirit which may produce undesirable flight characteristics. Vibrations may also be caused by incorrectly balanced blades, damaged bearings, bent shafts and other mechanical issues.
