Problémák és Megoldásuk
Revision as of 11:28, 21 August 2020 by PSzakra (Talk | contribs) (Created page with ": Növelje a ciklikus nyereséget (Gain-t) és/vagy növelje az adó giroszkóp-értékét. Állítson be exponenciális görbét az adóban.")
| A probléma leírása | Megoldás |
| Az imbolygó és/vagy a farok sodródik az inicializálás után. | Ellenőrizze a trimmeket és a subtrimmeket. A semleges helyzetű botoknak 0% -nak kell lenniük, lásd a Diagnostics fület. Növelje a botok holtjáték sávját az Advanced fülön. |
| Az oldalkormány vagy a ciklikus nem pontos. | : Növelje a ciklikus nyereséget (Gain-t) és/vagy növelje az adó giroszkóp-értékét. Állítson be exponenciális görbét az adóban. |
| Aggressive cyclic pitch movement or fast forward flight leads to rapid, large tail oscillations | Decrease pirouette consistency in the Advanced tab gradually by 10 until this disappears. Check the tail mechanics for binding. |
| Model oscillates in elevator or aileron axes | Decrease cyclic gain in Sensor tab. |
| Tail oscillates rapidly | Decrease gyro gain in the transmitter. |
| Flips and rolls are too slow or too fast | Increase/decrease rotation speed for Cyclic in the Sensor tab. |
| Pirouette is too slow/fast | Increase/decrease rotation speed for Rudder in the Sensor tab. |
| Servos jitter randomly without external influences | Check the cable connection between the receiver and the unit. |
| During stationary pirouettes model drifts | Check the Subtrim configuration in the Servos tab. It seems to be inprecise. |
| Aggressive elevator stick movement leads to bouncing | Increase elevator filter in Advanced tab and/or decrease cyclic feed forward in Advanced tab. |
| Cyclic feel is delayed or disconnected | Increase cyclic feed forward in Advanced tab. |
| Elevator servo is not moving when initialization is finished | Flight log from the previous flight was saved. View the log in the Diagnostic tab and fix reported problem. |
| Swashplate is jumping in a cycle when initialization is finished | The unit was started with the Rescue mode engaged. Turn off the rescue from your transmitter. |
| Rudder stop is not equal for both sides | Check rudder servo center position, rudder mechanics. You can also try to lower rudder limit for the side where bounce-back occur. |
| Positive and negative collective pitch is unequal | Enable Servos/Subtrim (tuning) and verify that servo arms are perpendicular, swashplate perfectly leveled and there is 0° between main blades. If yes, use the Servo Travel Correction. |
| Castle ESC is not arming | Set General - Throttle/Governor - Throttle Range Min. to 1060µs and Max. to 1940µs. |
| RPM readout is not correct with the ESC Telemetry | Temporarily enable General - Throttle/Governor - Governor and set Sensing Divider and Gear Ratio. Then turn the Governor off if governor from ESC is used. |
