A GeoLink felszerlése
1 Mounting on your helicopter
- Horizontal (0°) - connector is pointing to main rotor
- Horizontal (180°) - connector is pointing to tail rotor
1.1 Where to mount
- It is at least 5cm far from a rigid conductive parts such as carbon frame or bolts
- It is at least 5cm far from any electronics (especially servos)
- It is at least 8cm far from an electric motor
- It is at least 30cm far from any magnet (especially canopy magnetic mounts)
- It has clear sky visibility
- It is perfectly horizontally aligned
Choose a position which is not too far, so that provided cable is long enough. Placing module too far on the boom could lead to bad Center of Gravity of the model.
1.2 How to mount
Never mount GeoLink directly on a thick metallic parts, near a motor or any servo.
Do not cover GeoLink connector with any tape, glue or paint. Opening above the connector is used to determine ambient pressure and altitude.
Each circuit containing antennas is very carefully designed to achieve correct impedance. Impedance is electrical property which is directly determining performance of antenna. Impedance is changing immediately by placing any parts close to the circuit, especially near antenna. Because PCB is acting as a part of GPS antenna any change to the PCB, including screws has noticeable impact. Thus we highly do not recommend doing any hardware changes to GeoLink module.
The tape will shortly adhere on the surface tightly and can't be reused anymore.
1.4 Unmounting
Never pull the module in any way when mounted with double sided tape! This could bent or crack the plastic enclosure.
1.5 Mounting examples
1.5.1 LYNX Oxy 2
1.5.2 KDS Chase 360
1.5.3 SAB Goblin 700
2 Wiring
μSpirit Primary satellite port (SAT) Spirit Primary satellite port Spirit 2 Secondary satellite port (SAT2) Spirit Pro Secondary satellite port
3 Alignment
3.1 Alignment procedure
- Power up the Spirit unit.
- Place GeoLink at a flat, aligned horizontal surface anywhere on your model in order to get a precise reference. (for example the Spirit unit)
